4.0.2 https admin
jcarr
Level 3
Level 3
I've configured my 4.0.2 Unity system to use https. All appears to work properly except that when navigating from the main window to a detail window (any of them, it doesn't matter), I get an alert that the page contains both secure and non-secure items that I have to dismiss. It doesn't seem to matter wther I accept or reject the warning as the resultant display is the same. If I reject the non-secure items, I get a brief "action Canceled" in the pane. If I accept them, I get an insecure connection (no lock icon). Browser is IE 6.0
kenjohnson
Level 5
Level 5
I'm getting this error too in 4.0.4 when navigating to a subscriber view.
I've checked all the sources of the obvious elements on the page and they all appear to be https - but something obviously isn't.
I have set the virtual directories WEB, JAKARTA, and STATUS to require SSL connections - I even tried forcing it on the whole site just as a check - still the same error.
Looking at the source on the subscriber page that the selection screen brings up the only obvious reference to a non https entry i can find it:
var bStayLocal = true;
// part a)
if (strHomeServer != "") {
strHomeServer = strHomeServer.toLowerCase();
// part c)
// Do we recognize home server as ourself, or alternatively as our cluster partner?
bStayLocal = (strHomeServer == "server.mydomain.com");
if (bStayLocal) {
highTop.location.href = highTop.location.pathname + '?' + strExtra;
else {
// Please note! Following string is broken up to avoid CheckSACode.pl
highTop.open("http" + "://" + strHomeServer + "/Web/Sa/FrameASP/SubsFrame.asp?" + strExtra);
(the "server.mydomain.com" i replaced - it did reference our server - but it references the windows DNS name of the box wihich is not the public certificvate domain name...not sure if that's an issue?
- Ken
arief.muslim
Has this been solved already? I'm having the same problem with 4.0(4)sr1
Arief
It has not - we continue to experience the problem.
We are upgrading to 4.0(5) next week but I'm not confident the problem is likely to be fixed in a point upgrade - inspection of the code leads us to believe that some of the query calls are using http:// calss we can't get rid of - I hope 4.0(5) solves it - if not I will probably have to open a TAC case on it.
In the interests of time around graduation we've been living with it for the moment 😕
I take it you're having the same problem?
Ken Johnson
Mgr. Network Services
LeTourneau University
http://www.letu.edu
Dir. Marketing Communications
Cisco IP Telecommunications User Group
http://www.ciptug.org
