04-14-2016 03:15 PM - edited 03-19-2019 10:59 AM
8845 phones will not register when they are provisioned from PCP; i.e. they get dummy MAC then you change MAC address is changed from PCP
Comparing the cnf.xml of the BAT (Dummy MAC) and SEP (Real MAC) there is an indication about Blue tooth device change (might not contain correct hardware version)
Also , End point templates on PCP for auto provisioning are correct, but when you want to (replace) MAC address , the two field in 8845 intermediate field screen containing Switch Port Remote Configuration, change to Full 1000 ;
even if you change them there, the 8845 will not register. Till you save it manulally on CUCM
:( &^T!@&#%~!&@#_~#@_*
04-14-2016 05:23 PM
Hi there,
You may be hitting this bug;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy61387
05-20-2016 09:46 AM
Cisco should provide Fix for this in PCP 11.2;
the ES1 / ES2 on top of 11.1 has been partially fixed "half fix" : you need to save phone templates, before, and fix does not work with auto- provisioning!
you still need to change manually on call manager
