9.1 to 12.5 PCD migration where CUCM and CUPS OS admin usernames are different
I am tasked with migrating a Unity cluster and CUCM cluster from 9.1 to 12.5 utilizing PCD.
Upon cluster discovery the CUCM nodes are seen without issue but the CUPS nodes are failing as the OS admin username is different than the one specified in discovery for the CUCM nodes and I do not see a way to specify an additional username
I do not believe I can change the original OS admin username that was setup would the best course of action be to create another username? Is that possible on 9.1?
Or is it possible to do  separate discoveries;1 for CUCM nodes and 1 for the CUPS nodes?
You should be able to define a different user and pw for CUPS. See picture from our PCD for one of our CUPS servers.
Response Signature
Response Signature
