AAR With Unity Connection in SIP Integration
HI
What is the procedure to configure AAR in case unity connectionis in remote site and the Integration with CUCM is on SIP
CUCM and unity connection version is 8.5.2
Chris Deren
This one is tricky, and here is how I've accomplished this in couple of environments as this was the only way I could think of since AAR is not available on SIP trunks as oppose to SCCP ports:
configure your VM Route List to inlcude "Standard Local Route Group" as the last Route Group and configure
Called Party Transform Mask on this route group to point to a DID that is delivered to centralized site where UCXN is hosted.
This way when call arrives to site A and call needs to be redirected to VM per call forward no answer/busy the VM profile/VM pilot/Route Pattern, since the primary SIP trunk(s) are in different "location" and no bandwidth is available call will be rejected as there is no way to add AAR Group/destination to SIP trunk so the next available route group in the route list will be tried and since local route group is in the same "location" call will be send to it and then redirected to the masked DID and delivered to central site.  In CUCM matching TP is defined to match the DID on ingress side and translated to VM pilot. In UCXN you will need forwarding routing rule that matches this DID and sends the call to "attempt to sign-in" conversation.
HTH, please rate all useful posts!
Chris
Hi Chris
Thanks for sharing ,Also want to know why Cisco has provided option of AAR CSS in SIP trunk???
RC
RC,
My apologies, I did not explain this properly, AAR is available on SIP trunk just like it is on GW, but there is no way to define AAR destination on SIP trunk as you can with SCCP VM ports, hence the need for above configuration.
Chris
