Add subscriber on a Mixed-Mode environment
Flo.Matalis
Hi Experts,
CUCM: 11.5 SU6
Voice encryption is already working on the current system. Current cert was generated using Multi-SAN.
Client would like to add a new subscriber for a new site. Cannot utilize to use the existing server. My question is, should we regenerate the Call Manager cert, sign by our CA and push again the cert to the phones?
Any replies will be appreciated.
Flo
Chris Deren
Yes, the current multi SAN cert will be invalid after you add a new node and new cert will need to be signed and installed.
Thanks for your reply. Just want to confirm, if the multi SAN cert is already invalid, then does this mean that the voice encryption will not work also? So the only solution is to have it resigned again, upload to CUCM and push the CAPF cert to the phones? Thanks in advance!
