Advance Name Dictionary in Connection
AskQ2Forum_2
there's a setting in Connection under advanced > conversations  'use advanced name dictionary for voice recognition'
What will that actually do for voice recognition users . Turned off by default....Thanks, J
Jonathan Schulenberg
It makes the Nuance subsystem use a more complex grammer dictionary. The help file says not to enable it unless instructed to do so by TAC.
thanks for the reply.
