11-25-2015 11:09 AM - edited 03-19-2019 10:25 AM
I want to apply QoS for my collaboration network, so what I need is to match some kind of traffic with a especific value of DSCP. In this regard I need to know what are the ports used by cisco jabber for windows. Do you know this?. Thanks!!!
Solved! Go to Solution.
11-25-2015 01:10 PM
Table 3 Cisco Jabber for Windows port usage
Port |
Protocol |
Description |
Inbound |
16384 to 32766 |
UDP |
Receives Real-Time Transport Protocol (RTP) media streams for audio and video. You set these ports in Cisco Unified Communications Manager. |
Outbound |
69 |
UDP |
Connects to the Trivial File Transfer Protocol (TFTP) server. |
6970 |
HTTP |
Connects to the TFTP server to download Cisco Jabber for Windows configuration files. |
80 |
TCP (HTTP) |
Connects to services such as Cisco WebEx Meeting Center for meetings or Cisco Unity Connection for voicemail. |
143 |
IMAP (TCP) |
Connects to Cisco Unity Connection to access, download, and play voicemail messages. |
389 |
UDP / TCP |
Connects to an LDAP directory service. |
3268 |
TCP |
Connects to a Global Catalog server for contact searches. |
443 |
TCP (HTTPS) |
Connects to services such as such as Cisco WebEx Meeting Center for meetings or Cisco Unity Connection for voicemail. |
636 |
LDAPS |
Connects securely to an LDAP directory service. |
3269 |
LDAPS |
Connects securely to the Global Catalog server. |
993 |
IMAP (SSL) |
Connects to Cisco Unity Connection to retrieve and manage the list of voice messages for the user, and the voice messages themselves. |
2748 |
TCP |
Connects to the CTI gateway, which is the CTI Manager component of Cisco Unified Communications Manager. |
5060 |
UDP / TCP |
Provides Session Initiation Protocol (SIP) call signaling. |
5061 |
TCP |
Provides secure SIP call signaling. |
5222 |
TCP (XMPP) |
Connects to Cisco Unified Presence for instant messaging and presence. |
7993 |
IMAP (TLS) |
Connects to Cisco Unity Connection to access, download, and play secure voicemail messages. |
8191 |
TCP |
Connects to the local port to provide Simple Object Access Protocol (SOAP) web services. |
8443 |
HTTPS |
8443 is the port for web access to Cisco Unified Communications Manager and includes connections for the following: |
16384 to 32766 |
UDP |
Sends RTP media streams for audio and video. |
53 |
DNS |
Provides hostname resolution. |
1080 |
SOCKS5 Bytestreams |
Sends peer to peer file transfers. If port 1080 is in use, Cisco Jabber for Windows attempts to use the next available port in the range from 1081 to 1089. In on-premises deployments, Cisco Jabber for Windows also uses this port to send screen captures. |
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/vxc/english/vxme/9-x_ports_ref/b_vxme_ports-reference-guide.html#reference_C00D2A3EE122415385C77A53ED5CDC2B
refer below docs for QOS configuration and assistance:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/9_7/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97/JABW_BK_C4C679C9_00_cisco-jabber-for-windows-97_chapter_01.html#JABW_TK_S11EF173_00
https://technet.microsoft.com/en-us/library/cc771283(v=ws.10).aspx
Venkatesh.
-Do rate all helpful posts.
11-25-2015 01:10 PM
Port |
Protocol |
Description |
Inbound |
16384 to 32766 |
UDP |
Outbound |
69 |
UDP |
6970 |
HTTP |
80 |
TCP (HTTP) |
143 |
IMAP (TCP) |
389 |
UDP / TCP |
3268 |
TCP |
443 |
TCP (HTTPS) |
636 |
LDAPS |
3269 |
LDAPS |
993 |
IMAP (SSL) |
2748 |
TCP |
5060 |
UDP / TCP |
5061 |
TCP |
5222 |
TCP (XMPP) |
7993 |
IMAP (TLS) |
8191 |
TCP |
8443 |
HTTPS |
16384 to 32766 |
UDP |
53 |
DNS |
1080 |
Venkatesh.
