Audio Applications in Unity Fail-over
JustForVoice_2
Level 4
Level 4
Hi all,
I am going to install Cisco Unity with fail-over and what I remember, I should to rebuild the applications like Auto Attendant in secondary server. because this is not part of the replication.
Am I right? or no need to rebuild the applications?
Rob Huffman
Hi JFV,
That is no longer the case
How Standby Redundancy Works in Cisco Unity 8.x
Cisco Unity standby redundancy uses failover functionality to provide duplicate Cisco Unity servers for disaster recovery. The primary server is located at the primary facility, and the secondary server is located at the disaster-recover facility.
Standby redundancy functions in the following manner:
Data is replicated to the secondary server, with the exceptions noted in the "Data That Is Not Replicated in Cisco Unity 8.x" section.
Automatic failover is disabled.
In the event of a loss of the primary server, the secondary server is manually activated.
Changes to the following Cisco Unity settings are not replicated between the primary and secondary servers. You must manually change values on both servers.
Registry settings
Recording settings
Phone language settings
GUI language settings
Port settings
Integration settings
Conversation scripts
Key mapping scripts (can be modified through the Custom Key Map tool)
Media Master server name settings
Exchange message store, when installed on the secondary server
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/failover/guide/8xcufg040.html#wp1099338
Cheers!
Rob
5 Replies 5
JustForVoice_2
Level 4
Level 4
Actually I need to clarify this
"The fact that handlers are not replicated in the directory is  important. This means that, unlike subscriber information, audio-text  information is not shared between Unity servers on the same network. As such, if  multiple Unity servers work together to handle calls for an installation, you  must replicate your audio-text information between those servers on your own.  Currently, no tool can copy call-handler data or audio-text trees and duplicate  them on other servers (although the customer applications team has this on the  list of items to tackle as part of updated versions of the Audio Text  Manager)."
Rob Huffman
Hi JFV,
Registry settings
Recording settings
Port settings
Cheers!
Rob
Thank you too much Rob,
Do you mean waht I am talking about is very old
I need for Unity 7 with Domin and I found it:
Registry settings
Recording settings
Port settings
Thank you too much
Rob Huffman
Hi JFV,
You are most welcome my friend
Although much of the info in this excellent book is still applicable it was first published
Aug 3, 2004. So the portion of ATM config that you referenced is out of date.
Cheers!
Rob
Thank you man
