01-12-2016 04:26 AM - edited 03-19-2019 10:34 AM
Hi dear all.
I need help please.
I configured auto attended in unity I am using unity and CM version 9.1
But when a call is comming to any extension its not invoking greeting message .. Call coming directly to extension
What more should I do to have ivr before call.
Please help me as soon as.
01-12-2016 11:40 PM
Dear vivek,yes i create the route pattern and direcct routing to rule ill check it again and u get back in 10mints..
01-13-2016 12:12 AM
dear Vivek,
i did but fail to get greeting and caller input before ring.
need help please.
01-13-2016 03:04 AM
You need to filter out the efforts between CUCM and CUC, hence first check whether call is going out from CUCM or not so that can conclude our efforts in direction.
Do you know how to get SIP traces from RTMT (session trace log view -> real time data)? If yes, please get the traces and see if INVITE is being sent to CUC or not?
- Vivek
01-12-2016 09:14 AM
OK, so, you call AA, you dial a number and you want to???
Hear the greeting??
Ring the phone???
EXACTLY what are you doing right now, and what have you configured??
01-12-2016 11:43 AM
dear Jaime
Yes exactly I want the greetings when somebody call to any extension .
I configured all things from Cisco website unity connection and auto attendent .. But if any extension unable to answer its not opening ivr for voice mail .. I don't know does unity connection does this or not if no ans. But dear if any body calling to cucm how to enable greeting before ring .. And ask extension or operator for help.. I don't know wat I miss in configuration..
I would be very thankfull if this solve.. If you want to check it via team viwer also I am glad to share it tomarw wen u free To look the configuration.
Thanks and regards
01-12-2016 11:54 AM
I don't understand what question you're answering to...
You don't clearly explain the call flow, so I'm just going to assume until you provide clear information.
If you call DN 1111 who is your AA, and hear the greeting "if you know the extension, dial now", if you dial at that point in time, whether you reach the endpoint directly, or you hit the greeting, is based on the transfer settings from the subscriber (or call handler) you're trying to reach, same for any other transfer done within CUC. Meaning, you configure this for each individual.
Then you mention a greeting before ring????
Please provide a clear call flow, and explain what you want to happen to get assistance, if you don't clearly explain, and we don't understand, there's no chance to tell you what to do.
You might want to reach TAC so someone can actually take a look at your system to see what you have, and what to do in order to achieve what you want, assuming it's doable.
FYI, if someone is asking question for clarification, you usually don't rate those.
