11-09-2008 01:16 AM - edited 03-18-2019 09:57 PM
I tried to let calls from HQ to CME B-ACD through GK with codec G.729 but with no seccess.
WHY?
Here is my config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
h323
application
service queue flash:app-b-acd-2.1.0.0.tcl
param queue-len 10
param aa-hunt1 1111
param number-of-hunt-grps 2
param aa-hunt2 2222
service aa flash:app-b-acd-aa-2.1.0.0.tcl
paramspace english index 1
param handoff-string aa
param dial-by-extension-option 4
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 9000
param max-extension-length 4
paramspace english location flash:
param second-greeting-time 10
param welcome-prompt _bacd_welcome.au
param call-retry-timer 5
param max-time-call-retry 20
param voice-mail 2020
param service-name queue
sccp local FastEthernet0/1
sccp ccm 192.168.100.207 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register mtp001bd4706a19
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 3
associate application SCCP
dial-peer voice 10 voip
translation-profile incoming 9000
incoming called-number 3#9000
dial-peer voice 13 voip
destination-pattern 9000
session target ipv4:192.168.100.207
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 14 voip
service aa
incoming called-number 9000
codec g711ulaw
Any Replies?
11-09-2008 09:40 AM
use voice class codec in global config listing codec preference and voice-class codec in your dial-peers. let me know if this works.
11-09-2008 09:13 PM
B-ACD only supports G711 codec, try using transcoders if you desire G729.
HTH,
Chris
11-09-2008 09:56 PM
Thx for replies,
But:
1-If I use voice class codec,it will use G711ulaw.
2-I tried to make it use xcoder in CME with loopback dial peers as a work around but with no success.
Any suggestions.
01-14-2009 03:47 AM
Hello
I have the same problem, and i have tried to make xcode but it does not work. Did you found any solution?. It's like the b-acd does not use the xcode resources.
Thank you in advance.
