Backup to sftp using ssh-key aythentication
davidwild
Is it possible to use ssh-key auth instead of username password?
I have a UCS mediasense installation backing up to SFTP by username and password but I am pressured to use ssh- key.
I cannot find any guides and it seems not to be supported.
Thanks.
2 Accepted Solutions
Jaime Valencia
No, you cannot, these are the only options you can use:
utils disaster_recovery device add network device_name path server_name/ip_address username Number_of_backups
device_name mandatory name of the backup device to be added
path mandatory path to retrieve backup device from this
location
server_name mandatory hostname or ip address of the server where
/ip_address the backup file needs to be stored
username mandatory user id to connect to remote machine
Number_of_backups optional Number of backups to store on Network
Directory(default 2)
java
if this helps, please rate
Unfortunately there is nothing that can fulfil the kind of requirement you have on Media Sense. There is very limited  CLI access on MediaSense opposed to other UC applications, refer below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/11/User_Guide/CUMS_BK_M5B01864_00_ms-user-guide-11/CUMS_BK_M5B01864_00_ms-user-guide-105_chapter_011.html#CUMS_TP_CD5B3261_00
Deepak
Jaime Valencia
location
java
thanks very much for your answer.
just to be clear this is the backup of audio recordings to an SFTP server.
there is nothing in the GUI to use ssh-key and nothing in the cli either?
thanks again
Deepak
