BE4000 insufficient dsp issue
Vinod.s
Level 3
Level 3
Guys,
I am getting insufficient dsp resource in be 4k portal , i have installed pvdm4- 64 on mo and pvdm4-32 on nim card.
Any help to mitigate this.
How to check pvdm status of be4k , from ssh i can only see nim pvdm status.
7 Replies 7
Chris Deren
Post your "show run" and "show dspfarm all"
This is not normal router where yiu get show run or dspfarm....its be4000
I am getting this option only... attachedScreenshot_2020-02-09-22-07-08-320_com.android.chrome.jpg
Be4k is build on ISR 4K and I believe you can still get the output of the show commands.
Its having limited feature ...if this is possible then can you guide me...so that i can troubleshoot furthrr...
No, you can't, the CLI is locked down. It's the equivalent of the Linux on CUCM, you only get a handful of pre-configured commands and not full access. I believe there's also an equivalent of root access to get the normal IOS interface if TAC needs it. From what I know, there's only a handful of commands you can run, and they're mostly there for troubleshooting.
OP, your best option is to call TAC for this.
java
if this helps, please rate
You are correct... Even route patterns are also locked.
