BE6000
sulaymanbanni
Hi everyone. Can anyone help on how to change the IP address of virtual machines. I have BE6000 preconfigured with the server. The application servers have both got IP addresses, I want to change them to the company IP addressing range. The preconfigured server have the following IP addresses 172.27.199.10,
                                                        .11
                                                         .12
                                                         . 13
It seems you want to change the IP address of the UC applications.
you can refer the doc below the change the ip address of the UC applications. however make sure you have a proper plan of doing this as this might lead to db issues and most common one you might end up with is an "Database communication error" on gui page of cucm and might not be able to login to ccm page.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/8_6_1/ipchange/ipchg861.html
although its just two commands to change the IP address but if we do it without any plan/consideration would affect all other dependencies configured in application such as Gateways, trunks CTI ports etc etc. So, make a plan first and refer the document prior doing any changes.
