Dedicating PRI channels to a certain group?
art.lacie
With a small CCX (10 seats) and an overall 60 phone system (using be6k M) - I'm wondering the best way to use our 2 PRIs. If I wanted to, could I dedicate 15 channels of PRI1 to Contact Center, and the remaining channels + PRI2 to the rest of the building? If that's how it works... I'm trying to get a grasp of the more technical details surrounding the setup by the time the IT rolls in.
Thanks./
Jaime Valencia
Yes, that's a fractional PRI
https://supportforums.cisco.com/discussion/11179151/fractional-t1-pri-mgcp-and-h323-call-manager
http://www.techexams.net/forums/ccnp-voice/72520-fractional-pri-config.html
That is only supported with H.323, not with MGCP, you CAN configure it, but won't be officially supported.
java
if this helps, please rate
Jaime Valencia
java
