08-15-2016 11:58 PM - edited 03-19-2019 11:28 AM
Hi.
If you want to add more than 5 applpication in the BE6000K platfrom, can you buy two or more and spread the applcations? So the servers will wrok as one?
Solved! Go to Solution.
08-16-2016 07:17 AM
Yes, you would need to either buy another 6K, or, once you have one 6K in the cluster, you can also buy any other regular UC on UCS option, as long as you keep in mind the limitations regarding users/devices of your 6K box.
08-16-2016 07:17 AM
