block incoming calls to a particular extension in mgcp gateway
Vysakh Sundar
How to block incoming calls to a particular extension in mgcp gateway in cucm 12.5
Calls to extension 245 from outside should be blocked
only internal calls are allowed
2 Accepted Solutions
The easiest would be to not have the DN 245 in a partition that is visible in the CCS used on the MGCP GW.
Response Signature
The best option to keep it on a different partition  and don’t allow gateway to reach this partition.
Response Signature
Response Signature
Response Signature
