Block Unknown Number
scooter817
Level 2
Level 2
Hi Everyone
I wanted to know is there a way to block unknown numbers, I thought that by checking the reject anonymous calls box on the line would stop it but they are still getting through. If anyone has done this before I would greatly appreciate some help with this and thanks in advance.
Eric
Jaime Valencia
Plenty of info if you google: cisco block anonymous calls
https://supportforums.cisco.com/discussion/11417341/block-incoming-anonymous-calls
https://www.youtube.com/watch?v=24-6ifUXvdI
https://www.byteworks.com/blog/allow-or-block-anonymous-calls-into-cisco-communications-manager-lua-script-update/
https://lists.gt.net/cisco/voip/86237
java
if this helps, please rate
Jaime Valencia
java
I opened a TAC case and they told me that it couldn't be done and you helped me fix this in 30min with this article, as usual thanks Jaime.
Really???
Whoever got your case definitely had no idea, you can see there are a lot of references in google (and more than one way to do this), and even more if he looked at old TAC cases asking the same thing.
java
I kinda figure that and that's the reason I posted on hear because I knew it could be done. And now that I know I can add this to my knowledge base and thanks again.
