Blocking incoming call for specific extension under CUCM 7.
Dear All ,
  I have one Voice Gateway cisco 3800 and call manager 7 . i want to block all incoming Call from outside to EXT :111, 222 , 333 and make this EXTs available just  internal or inside the CLUSTER  . i tried to use translation profile on the Voice Gateway . But, there is something missing can anyone help in this case . the configuration on the Voice Gateway i used it  as following :
voice transltion-rule 1
rule 1 reject /^111$/
rule 2 reject /^222$/
rule 3 reject /^333$/
voice translation-profile call_block
translate called 1
dial-peer voice 1 voip
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
i will be thankful for any help toaccomplish this
warm regards
Mohamed Abdullah
keglass
Level 7
Level 7
Mohamed,
This community does not provide technical support and is not staffed with technical support experts.  I recommend you post this and future technical support questions to the Cisco Support Community (https://supportforums.cisco.com/index.jspa).
We do encourage you to participate in the Cisco Collaboration Community and to also join our Cisco Collaboration User Group program!  In the community, we encourage your discussion/sharing around collaboration topics and Cisco Collaboration Solutions, including business and IT requirements, industry trends, process, culture/organization issues, how collaboration can be used to transform businesses, vendor selection, adoption, training, architecture, licensing, and product features/functionality. If you are a customer or partner, you can also join the user group program to be eligible for member-only events and influence product direction.
We hope to hear from you again.
Kelli Glass
Moderator for the Cisco Collaboration Community
david.xu
I think the simplest way is not to assign a DID number to these ext., then nobody can call it from external, or assign these ext. with internal only calling searching space.
