Bulk Add users to a DL in Unity Connection 8.5
angel-moon
Level 3
Level 3
All,
does anyone know of a way to add users in bulk to a Distribution Lists in Unity Connection 8.5?
Thanks in advance!  All replies rated.
Rob Huffman
Hi Angel,
Have you looked into this excellent tool
Distribution List Builder for Connection
http://www.ciscounitytools.com/Applications/CxN/PublicDistributionListBuilder/PublicDistributionListBuilder.html
Cheers!
Rob
Rob Huffman
Hi Angel,
Cheers!
Rob
Thanks Rob!
Thanks Rob.  One follow up Question.  Is this the ONLY way or the BEST way?
Rob Huffman
Hi Angel,
You are most welcome my friend
I am a huge fan of the Unity Tools suite, but this is not the only way. You can also
add users quite quickly in large numbers via the SA itself depending on what search criteria
you use when you go to "Add Users" from the specified DL. So I can't say which is BEST as that
determination is in the "eyes of the beholder".
Cheers!
Rob
