bulk remove users from access control group
shloki193
Hi all
need help with finding out if it is possible to bulk remove users from access control group on cucm ??
help will be appreciated
6 Replies 6
  • Image 1 i have added few users in Access control group called AXL.
  • To remove the users from the AXL group i selcted the users and  used delete selected option
  • Associated users got removed from the AXl Access Control Group.
Response Signature
thanks for your quick reply
i had this solution suggested but the customer is trying to get a solution for a big group of users .
i am trying to see if it is possible to remove the users with the bulk administration menu
since users can be uploaded an updated through the bulk menu - is there any way to remove this particular field or group through this menu ?
thanks
USE Import/Export method in BULK. i have tried adding the users and it worked  but not tried removing the users.
Response Signature
I use BULK Export/Import to remove acces control group 1,2 and 3 and it doesn't work if i leave the field blank.  Users still have access control group when I ckeck in the end user page into CUCM.  Do I have to use a value like "1" or "null" or something else to remove?
To keep the user's password, do I have to indicate a value in the "password" column.
Thanks for your help
mcossette
Hi, did you received an answer for using BULK?
Not yet
