02-25-2013 08:28 AM - edited 03-19-2019 06:20 AM
I'm using Call Manager version 8.0(3) and wonder is there a way I can block a specific inbound 866 or 800 phone number?
Thanks!
02-25-2013 08:50 AM
Hi Kristy,
For H.323;
Call Blocking Configuration Examples
Reject Calls
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
If your Gateways are MGCP, added with the release of CUCM 8.x
From Dan @ Cisco for MGCP
https://supportforums.cisco.com/docs/DOC-18367
Cheers!
Rob
"What you don't have you don't need it now"
- U2
02-26-2013 05:29 AM
Thank you!!
02-25-2013 09:01 AM
Dear
A- based on your Call manager
1- You have to ceate partiton for eample (CL-PSTN-SCREE-PT).
2-You have to ceate CSS twhich will include the above partition which is called (
CL_Tenant-Control_CSS).This CSS is assigned to patterns in CL_PSTN-Screen_PT and it contains partitions that have phone DNs and other patterns that route to devices or applications on the CUCM cluster.
you can repeat the same steps for 866
B-On H323 gateway
Thank you
Please rate if this will help
02-26-2013 05:30 AM
Thanks for your help and screenshot example.
