Call blocking CUCM 8.0(3)
waldronks
I'm using Call Manager version 8.0(3) and wonder is there a way I can block a specific inbound 866 or 800 phone number?
Thanks!
Rob Huffman
Hi Kristy,
For H.323;
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
Reject Calls
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
If your Gateways are MGCP, added with the release of CUCM 8.x
From Dan @ Cisco for MGCP
https://supportforums.cisco.com/docs/DOC-18367
Cheers!
Rob
"What you don't have you don't need it now"
- U2
Thank you!!
islam.kamal
Level 10
Level 10
Dear
A- based on your Call manager
1- You have to ceate partiton for eample (CL-PSTN-SCREE-PT).
2-You have to  ceate CSS twhich will include the above partition which is called (
CL_Tenant-Control_CSS).This CSS is assigned to patterns in CL_PSTN-Screen_PT and it contains partitions that have phone DNs and other patterns that route to devices or applications on the CUCM cluster.
you can repeat the same steps for 866
B-On H323 gateway
Thank you
Please rate if this will help
Thanks for your help and screenshot example.
