Call Manager Dis-Contiguous Number Range
Jinesh Patel
HI,
My company uses a DDI range for example, 0208 5556789 - we use a translation pattern to change this (or rather, 556789) into internal numbers/extensions, example, 1XXX.
My question is this - as we start to bring in remote sites onto the centralized system, to use the ISDNs that we have at our HQ, we would like to use a different DDI range (we can't contiguously add numbers to this range according to our TELCO) and therefore i was wondering where we would start in terms of configuration with an additional dis-contiguous number range?
I'm sure there are many things that we need to consider/change to get this working but i'm not sure even where to start.  I need to justify getting outside help for this (if necessary) but ideally, if it's something that we can do internally, then this is preferable.
Many thanks
Jay
Manish Gogna
Hi Jay,
You will need to start with gateway / CUBE where you need to check / configure the following as per the new DID range:
dial-peer destination patterns
translation rules ( if required )
On CUCM you will need to configure / modify translation patterns if they are being used to route the calls to IP phones.
Manish
