Call routing based on calling number
travail223
Community Member
The topology existing is :   operator <---> Cisco Voice gateway with E1 card <---> CUCM
Ís there any possibility to redirect a call based on calling party number either on  Voice gateway or cucm.
For more clarification, if a caller A and a caller B dial the same DID number for example 991221212, I want to redirect the caller A to the extension 2000 and the caller B to the extension 3000.
Match the call using the incoming dial-peer with the calling number and translate the called number.
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
Response Signature
Response Signature
The solution provided by @Nithin Eluvathingal is the preferred solution. However, if for some reason you are unable to implement the solution on the gateway there is a way to do it on CUCM. It's complicated and messy, but does work.
Collaboration Knowledge Base: Blocking Calls Based on Calling Party ID
https://community.cisco.com/t5/collaboration-knowledge-base/blocking-calls-based-on-calling-party-id/ta-p/3113978
Maren
