11-07-2025 01:09 AM
The topology existing is : operator <---> Cisco Voice gateway with E1 card <---> CUCM
Ís there any possibility to redirect a call based on calling party number either on Voice gateway or cucm.
For more clarification, if a caller A and a caller B dial the same DID number for example 991221212, I want to redirect the caller A to the extension 2000 and the caller B to the extension 3000.
Solved! Go to Solution.
11-07-2025 05:21 AM
Match the call using the incoming dial-peer with the calling number and translate the called number.
11-07-2025 05:21 AM
11-07-2025 06:45 AM
The solution provided by @Nithin Eluvathingal is the preferred solution. However, if for some reason you are unable to implement the solution on the gateway there is a way to do it on CUCM. It's complicated and messy, but does work.
Collaboration Knowledge Base: Blocking Calls Based on Calling Party ID
https://community.cisco.com/t5/collaboration-knowledge-base/blocking-calls-based-on-calling-party-id/ta-p/3113978
Maren
