call routing to an assistant
aguy
Im trying to figure out a way to:
  1. have a call come in to a line
  2. if the user doesnt pickup after 3 rings it goes to an asstant
  3. if the assistant doesnt pickup then it goes to the user's voicemail
Whatever method I use has to be browser based.  ie can use a windows application.
Any ideas?
You could use IPMA
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
What call control do you use and version????
java
Sorry forgot. Using CUCM/UM/CUPS 8.6
Andre
You could use IPMA
java
java
