Callmanager and Unity integration
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-12-2012 12:55 AM - edited 03-19-2019 05:51 AM
I have a CUCM 6.1.2 and Unity 5.0 running and are also integrated. Now I want to upgrade my CUCM6.1.2 to version 8.5 and also convert the device license units (DLUs) to user Connect Licenses (UCLs). The Unity 5.0 remains same.
Will this upgrade affect the already established integration between the Unity and the CUCM? Will I have to do any additional thing to maintain the integration between unity and cucm?
regards,
Peter.
- Labels:
UC Applications
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-12-2012 04:57 AM
Just make sure to use the right TSP and that should be it
SCCP Compatibility Matrix: Cisco Unity, the Cisco Unity-CM TSP, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
