11-21-2024 07:10 AM
Hello all,
I have this scenario :
Server (PBX) connected on cucm via sip trunk , the cucm connected via PSTN sip trunk for external calls.
PBX ---- CUCM ----PSTN
-When a user from PBX call a normal PSTN numbers the call is passed via cucm after it arrive at PSTN and function correctly .
- When the same user call an PSTN anonymous nmbers the call is rejected by CUCM with termination cause code (1) Unallocated (unassigned) number
When i checked the normalized message i found SIP /2.0 404 no found , and on invite message:
The cucm send the 404 not found to PBX.
Do you have any idea of this problem ? does the cucm not know the format sip:PBX_GW@adress ip of PBX ?
Could you help me please
Best regards
11-25-2024 02:34 AM
Thank you @Roger Kallberg , for your return ,
I tested the first call by DNA and it matched with pattern and routed .
But i don't know how to test the second call ,
I have in the invite from :"PBX_GW" <sip:PBX_GW@adress_ip_of_PBX>
to :<sip:0654338940@adress_ip_of_cucm>
What i can put in the calling party on this example
Best regards
11-25-2024 10:25 AM
PBX_GW
11-26-2024 01:24 AM
in the calling party accept only Numeric Values
When i put the PBX_GW on calling party it give me the message : Please enter only Numeric Values,Characters, #, *, ., :, +, @ for Calling Party
Best regards
11-26-2024 02:26 AM
Then you can not do DNA for that call scenario. Next thing to do is to look in the SDL traces to see what the call routing logic does for these two call.
11-26-2024 03:34 AM
Thank you @Roger Kallberg for your return ,
With DNA test on analyzer input on directory URI can i put: PBX_GW@adress_ip_of_PBX
Best regards
12-26-2024 07:29 AM
Hello there,
Do you have confirmation that your PSTN will accept the number in this format? May be your PSTN is accepting the numbers only in E164 format.
Thank you.
