Calls issue on SIP SRST
Darryl.Lipat
Hi everyone,
i just configured my srst to support sip phones. During fallback all phones (sccp and sip) are able to register to the srst router. First i try sip to sip are working, then sip to sccp are also working, but when i tried sccp to sip i get an error tone. Then all calls either sip or sccp started to fail. I observered that call failure starts when sccp calls to sip phones.
Try rebooting the sip phones and call was restored (sip to sip and sip to sccp). But again when sccp to sip the call fails and then every call fails again. Upon dialing it just dead air and after a couple of seconds there is an error tone. Try adding a dial-peer but it did not work
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  min-se 1200 session-expires 1200
  error-passthru
  registrar server expires max 600 min 60
  asserted-id pai
  no update-callerid
  early-offer forced
  history-info
  no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class codec 2
codec preference 1 g729r8
codec preference 3 g711alaw
voice register global
system message Backup Mode
max-dn 200
max-pool 42
voice register pool  1
id network 10.1.2.0 mask 255.255.254.0
application sip.app
incoming called-number
dtmf-relay rtp-nte
voice-class codec 1
no vad
application
global
  service alternate Default
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.2.12
ccm-manager config
mgcp
mgcp call-agent 10.1.2.12 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.2.11 port 2000
max-ephones 42
max-dn 100
application ctapp
system message primary System on Backup Mode
system message secondary Backup Mode
transfer-pattern ....
time-zone 41
Rejohn Cuares
Level 4
Level 4
Enable debug on your VG, recreate the issue and post the output here.
debug ccsip all
debug voip ccapi inout
debug sccp event
debug sccp config
Please rate replies and mark question as "answered" if applicable.
Just fixed the problem. it seems that there is missing config on my call-manager fallback. also during srst mode, i was not able to calls between sccp. I just add "appliation default".
@rr,
i could not get the logs, sccp phones will disconnect upon issuing the debug command. thanks for reply
