Can't add or modify distribution lists
bdecout
Unity 4.2.1.
I can create a new DL with SAWEB but I can't add members or modify it.
All the options are grayed out.
I can use the public DL builder tool to add members but that's about it.
What would cause the unity administrator tool to disable the option to modify DLs
Ginger Dillon
Hi -
Try creating the distribution list in Exchange first and then import into Unity. Once your subscribers record a spoken name, they will show up as members of the list in Unity.
Ginger
