ā12-04-2022 11:56 PM
So, I have a Cisco Webex Desk pro running over SIP registered to CUCM. I'm attending meetings where they are sharing slides but all i can see is their camera. I went through the configurations in the GUI and on the system itself but cannot see what i need to change to view both slides and their camera.
please help!
Solved! Go to Solution.
ā12-05-2022 03:10 AM - edited ā12-05-2022 03:11 AM
Joining Webex Meeting or something else?
If Webex, do you have Webex Edge for Devices configured with Optimized Join Experience? If not, thatās the best user experience.
If you canāt use Control Hub for some reason then you need to ensure BFCP can negotiate from endpoint through CUCM and Expressway; it needs to be enabled on the Expressway zones the call traverses. In this scenario it is also suggested, but not required, to also permit iX Media between endpoint and Webex.
ā12-10-2022 02:46 PM
thanks Jonathan it turns out the other end was using an avaya station that was not properly configured to push content across the trunk between their CUCM and ours
