11-18-2024 10:27 PM
Can we do the cube high availability with different model of cisco router like C2911 with C8300?
Solved! Go to Solution.
11-18-2024 11:06 PM
I would say no, especially with that big of a gap between models that you mention as there will be such a big difference in IOS versions between the two. Possibly it might work between two different models within the same product family, but not with two from different generations of routers.
11-18-2024 11:06 PM
11-18-2024 11:45 PM
Thank you very much Roger
