CCM help
darriellew
hi,
where i work a phone extension was configured in the past to have external calls from a direct outside line forwarded to it. How do i remove these configurations to stop this from happening?
mchandak
Level 7
Level 7
If you know what the external number was being received by CM, then you can use Route Plan Report (CCMAdmin Page ---> Route Plan ---> Route Plan Report) to find the number and delete it.
mchandak
Level 7
Level 7
GREAT THANKS IT WORKED!!!!
