How to get cummulative MS patches for 2006/2007 for Unity?
auraycats
I found Unity recommended 30+ MS patches for Unity. My last patches was at the beginning of 2005 and have a big gap to keep the Unity up to speed on MS patches. I was told to download each patch i.e. ms06-22 918439 and load one at a time. Is there a fast way to get all patches for year 2006 & 2005?
Thus, I can apply in one goal instead of 30+ times. Does the Cisco owned patches included MS patches. I am running Unity 4.0 Win 2000 sp4. Au Ray
Tommer Catlin
There is not a "rollup" service pack installer like in Callmanager. CCM will install all the patches in one large bulk. Unity, sad to say.. one at a time. But I know you can, if you are a good scripter, "tie" the patch installs together to have them install all at once in a batch.
Will Cisco improve the process in newer release? Au Ray
You will have to check with your local Cisco SE or contact TAC for more information. We all hope they can supply a "rollup" pack once a month because it does take a lot of time.
good luck!
