07-21-2006 08:54 PM - edited 03-18-2019 06:10 PM
I'm trying to get my cisco 2811 with an AIM-CUE to send calls to voicemail. Right now internal/external calls are not getting to VM and I'm not sure why. I was considering using a translation-rule but I may loose some functionality (see attch config).
07-22-2006 07:44 AM
Did you initialize CUE and setup call-in numbers for VM to 6000 ? Does the voicemail even answer your call ?
When you call into CUE, because you have dialplan pattern configured your number will be transformed to a 10 digit. You can fix this by two ways.
a. Use E.164 numbers for each mailbox in CUE as 10 digit numbers.
b. Use a translation rule on the voip dial-peer (SIP) and translate 10 digits to 4 digits.
07-22-2006 11:36 AM
Yes, I did initilaize CUE and when I dial 6000 from any ephone the CUE-VM system answers.
