CDR report for Trunk Utilization error code 10012
jaheshkhan
Level 5
Level 5
While generating a CDR report for Trunk Utilization the below error appeared
Please help the right steps to solve this issue. I think this issue started after upgrading from 11.5 SU3 to 11.5 SU8.
jaheshkhan
Level 5
Level 5
I restarted publisher server first and then after rebooting it completely restarted subscriber server as well..
Then every thing seems working properly
6 Replies 6
Kaloyan
Please ensure that the "CDR Flag Enabled" service parameter is set to "True" on all call processing CUCM nodes. Then verify that the "Continuous Loading 24/7" setting is enabled from the CAR page > System > Scheduler > CDR Load.  Also verify that the below listed services are running and try restarting them:
On PUB:
- Cisco CAR Scheduler
- Cisco CDR Agent
On all call processing SUBs:
- Cisco CDR Agent
I hope this helps.
I already did what you mentioned. but after that i couldnt test it.
For your information:
"CDR Flag Enabled" service parameter is set to "True" - YES
"Continuous Loading 24/7" setting is enabled ---- YES
On PUB:
- Cisco CAR Scheduler --- YES running. Also restarted.
- Cisco CDR Agent  ---- YES . restarted
- Cisco CDR Agent --- YES. Already restarted.
what will I do if for some reason if it didnt work? what I need to verify?
Cross verified. Issue still there. Any more suggestion?
jaheshkhan
Level 5
Level 5
Any suggestion? what we need to do? is it corrupted? the issue started after upgrading cucm.
jaheshkhan
Level 5
Level 5
Any more suggestion??
jaheshkhan
Level 5
Level 5
