CER No Valid Upgrade Options Were Found
jamie.mai
Hello, my CER is on system version: 11.5.4.20000-3, I need to upgrade so downloaded UCSInstall_CER_12.5.1.25900-14.sha512.iso
From the release notes it looks like I can do a direct upgrade with no cop file but when attempting to load it says "no valid upgrade options were found" and shows "name does not match any filter pattern" by the iso file. Am I missing something here? Thanks!
For other CVOS systems you need to install a COP file for the system to recognise any files that are signed with the new sha512 keys. Quite likely it is also needed for CER.
Response Signature
Leonardo Santana
Hi Jamie,
Are you mapping the correct folder where the file is located?
Leonardo Santana
*** Rate All Helpful Responses***
Thanks for the reply, yes, it sees the file but says "name does not match any filter pattern" by it
Response Signature
That was it thanks Roger, I wish they would mention that in the release notes.
