Changing 300 Directory Numbers - Callmanager 8.5
Simon Hammer
I have to change a few hundred Directory Numbers and want to avoid doing it number by number. I found a few older entries that the only way is to export phones with all details and insert the changed file. Because it's a few years old, is there any new procedure I could do? Or still the same...
Aaron Harrison
Depends what you want to do. When you say change DNs, you mean change the number of each DN, or some other property? I wrote a little command to update DNs, see here:
https://supportforums.cisco.com/thread/2119442
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
