06-07-2011 12:12 PM - edited 03-19-2019 03:04 AM
Hi everyone,
How can i add new ata 187 to CCM 7.1.3. I have just read that it is supported on
Cisco UCM Versions 7.1.5, 8.0.2, or higher...
is there any walkaround ?
can I upgrade to 7.1.5 since we still don’t have SmartNet??
THX,
Ivan
Solved! Go to Solution.
06-07-2011 01:12 PM
Open the main page of IP Telephony (For some reason announcements don't show up in Unified Communications Applications where you posted this.)
Your question (Can i go from X to Y part) is covered in the announcement:
As for the procedure:
Software Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-07-2011 12:23 PM
Support for that device is only on 7.1(5) and higher, you need to upgrade.
Cisco UCM Version Compatibility
• Cisco UCM Versions 7.1.5, 8.0.2, or higher
java
06-07-2011 12:44 PM
I am unable to open your link....
but I find you’re answer on same subject hear...
https://supportforums.cisco.com/message/3332030
so now I just need to find some good tutorial how to upgrade since I didn’t make any upgrade on CCM....:-)
can i go directly from 7.1.3 to 7.1.5??
THX,
Ivan
06-07-2011 01:12 PM
Software Upgrades
java
06-08-2011 03:16 AM
Thank you very much...! You save me loot of time....
06-10-2011 12:45 AM
Ok, one more question while files are downloading....
I will upgrade from:
7.1 (3b)SU2 to 7.1.(5b)SU3 (7.1.3.32900-4 to 7.5.1.32900-2)
when i click to download version i woud like there are two files:
Cisco Unified Communications Manager Version 7.1 | UCSInstall_UCOS_7.1.5.33900-10.sgn.iso | 3534242 | |
Cisco Unified Communications Manager Version 7.1 | cmterm-devicepack7.1.5.33052-1.cop.sgn | 316180 |
so i need to instal fist one.... and this second one after instaling first one?
is this for suporting new device like ATA 187??
p.s. when upgrading telephone will normaly operate??
THX,
Ivan
06-10-2011 06:31 AM
yes, but the second one after you do the version switch.
yes
java
06-13-2011 03:36 AM
Today I start upgrading ... but this massage show up:
This version number inside the selected upgrades does not match the filename!!
now again I am downloading.... :-(
06-14-2011 05:57 AM
update.....
successfully updated but :-)) call forward is not working any more on Cisco 7941 phones :-(((
any sugestion?
