Cisco Call Manager 12 Installation
amalmichaelvj
Hello Cisco team,
I am looking to install Cisco Unified call manager in 3 customer location.Each Site is individual deployment only.i need  Cisco 8851,7821,CP3905 IP phones registration in Cisco Unified call manager.I have Cisco ISR4321 Router as voice gateway with a PRI connection in it.I also Have Cisco VG350 Voice gateway to connect Analog Phones..
Some who is expert please help me with Documents for installation,Configuration examples,Videos regarding these setup..
My Scope of work
1.Install Cisco Unified call manager in Customer hardware and basic setup to be completed
2.Register phones in Cisco Unified call manager.
3.Configure ISR4321 as gateway and PRI  connection should be configured,Add Voice gateway  in Cisco Unified call manager.
4.VG350 Gateway need to be add in Cisco Unified call manager,Analog phones need to be registered,FXO port in VG350 configuration.
5.Cisco Unified call manager primary gateway as ISR4321(Pri Connection) and Secondary gateway as VG350 (FXO Connection).
someone kindly assist me
2 Accepted Solutions
Jaime Valencia
All the CUCM documentation is here:
https://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/tsd-products-support-series-home.html
And you can google how to for a lot of things and found references.
Given that it seems you have never done this, I would strongly advise to hire a reputable consultant or reach out to a Cisco partner with UC specializations to get assistance with this. Building a CUCM environment requires of previous knowledge on how to design and configure it.
java
if this helps, please rate
Already did, the documents that cover all that, are in the link I provided. That would be the official Cisco documentation.
Additionally, if you do not understand call routing in CUCM, you would need to read the dial plan chapter from the SRND to understand how to design a dial plan for your organization.
java
5 Replies 5
Jaime Valencia
java
Tahnks for reply..
Can you refer me Cisco CUCM basic installation Configuration example which genarally use.So that i can test in lab envoirnment.
1.install CUCM in ESXi
2.Basic setup for phones registration and basic call features
 i have search many doc,But i am not pretty sure which one to follow..
kindly help me on this
java
Hello Jaime,
Thanks for the information..
Please look on My BOM,In my Solution there is no BE6M-M5-K9...How can i deploy CUCM in seprate hardware.
Where can i download the file to install CUCM..
25.0 R-UCL-UCM-LIC-K9 Top Level SKU For 9.x/10.x User License - eDelivery
25.0.1 CON-ECMU-RUCLUCK9 SWSS UPGRADES Top Level SKU For 9.
25.1 CUCM-VERS-12.0 CUCM  Software version 12.0
25.2 LIC-CUCM-12X-ESS UC Manager-12.x Essential User License
25.2.0.1 CON-ECMU-LICC1CMS SWSS UPGRADES UC Manager-12.x Essential User License
25.3 LIC-EXP-TURN Enable TURN Relay Option
25.4 LIC-EXP-E-PAK Expressway Series, Expressway-E PAK
25.5 LIC-UCM-12X-ESS UC Manager Essential 12.x License
25.6 EXPWY-VE-C-K9 Cisco Expressway-C Server, Virtual Edition
25.7 LIC-EXP-E Enable Expressway-E Feature Set
25.8 LIC-EXP-GW Enable GW Feature (H323-SIP)
25.9 SW-EXP-8.X-K9 Software Image for Expressway with Encryption, Version X8
25.1 LIC-EXP-AN Enable Advanced Networking Option
25.11 EXPWY-VE-E-K9 Cisco Expressway-E Server, Virtual Edition
25.12 LIC-EXP-DSK Expressway Desktop Endpoint License
25.13 LIC-SW-EXP-K9 License Key Software Encrypted
25.14 LIC-EXP-SERIES Enable Expressway Series Feature Set
25.15 LIC-CUCM-12X-ENH UC Manager-12.x Enhanced Single User License
25.15.0.1 CON-ECMU-LICCUCHM SWSS UPGRADES UC Manager-12.x Enhanced Single User Lic
25.16 LIC-UCM-12X-ENH UC Manager Enhanced 12.x License
26.0 VG350-96FXSE-EM/K9 Cisco VG350 96 FXS OPX-Lite Bundle
26.0.1 CON-SNT-VG3509K9 SNTC-8X5XNBD Cisco VG350 96 FXS O
26.1 CAB-ACSA AC Power Cord (South Africa), C13, BS 546, 1.8m
26.2 SL-VG350-UC-K9 Cisco VG350 Unified Communications License
26.3 MEM-CF-256MB 256MB Compact Flash for Cisco 1900, 2900, 3900 ISR
26.4 VG350-FANASSY Cisco VG350 Fan Assembly
26.5 PVDM3-256 256-channel high-density voice DSP module
26.6 HWIC-BLANK Blank faceplate for HWIC slot on Cisco ISR
26.7 RPS-COVER-3900 Cover for empty 2nd Power Supply slot on Cisco 3925/3945
26.8 VG350-SPE150/K9 Cisco VG350 Motherboard
26.9 MEM-3900-1GB-DEF 1GB DRAM (512MB+512MB) for Cisco 3925/3945 ISR (Default)
26.1 SL-VG350-IPB-K9 Cisco VG350 IP Base License
26.11 PWR-3900-AC Cisco 3925/3945 AC Power Supply
26.12 SVG350UK9-15204M Cisco VG350 Series IOS  UNIVERSAL
26.13 SM-D-48FXS-E Cisco 48 Port FXS OPX-Lite Double Wide Service Module
26.14 VIC2-4FXO Four-port Voice Interface Card - FXO (Universal)
27.0 ISR4321-V/K9 Cisco ISR 4321 Bundle, w/UC License, CUBE-10
27.0.1 CON-SNT-ISR4321V SNTC-8X5XNBD Cisco ISR 4321 UC Bundle, PVDM4-32, UC L
27.1 SL-4320-IPB-K9 IP Base License for Cisco ISR 4320 Series
27.2 SL-4320-UC-K9 Unified Communication License for Cisco ISR 4320 Series
27.3 PWR-4320-AC AC Power Supply for Cisco ISR 4320
27.4 CAB-AC-C5-IND AC Power Cord, Type C5, India
27.5 MEM-FLSH-4G 4G Flash Memory for Cisco ISR 4300 (Soldered on motherboard)
27.6 MEM-4320-4G 4G DRAM for Cisco ISR 4320 (Soldered on motherboard)
27.7 FL-CUBEE-5 Unified Border Element Enterprise License - 5 sessions
27.8 SISR4300UK9-316S Cisco ISR 4300 Series IOS XE Universal
27.9 NIM-BLANK Blank faceplate for NIM slot on Cisco ISR 4400
27.1 NIM-1MFT-T1/E1 1 port Multiflex Trunk Voice/Clear-channel Data T1/E1 Module
27.11 PVDM4-32 32-channel DSP module
27.12 FL-CUBEE-25 Unified Border Element Enterprise License - 25 sessions
28.0 FL-CUBEE-5= Unified Border Element Enterprise RTU license - 5 sessions
29.0 CP-3905= Cisco Unified SIP Phone 3905, Charcoal, Standard Handset
29.0.1 CON-SNT-CP3905 SNTC-8X5XNBD Cisco Unified SIP Phone 3905, Charcoal,
30.0 CP-3905-PWR-IN= Power Adapter for Cisco Unified SIP Phone 3905, India
31.0 CP-8851-K9= Cisco IP Phone 8851
31.0.1 CON-SNT-CP8851K9 SNTC-8X5XNBD Cisco UC Phone 8851
32.0 CP-BEKEM= Cisco IP Phone 8800 Key Expansion Module
32.0.1 CON-SNT-CPBEKEM SNTC-8X5XNBD Cisco IP Phone 8800 Key Expansion Module
33.0 CP-PWR-CUBE-4= IP Phone power transformer for the 89/9900 phone series
34.0 CP-PWR-CORD-IN=
Power Cord, India
You order the bootable media via PUT and the UC virtualization wiki contains all the guidelines for using 3rd party HW, you would need to validate your server with those to determine if it's compatible or not.
java
