cisco call manager work ,but https and web browser couldn't work
ozden ozdugun
version 9.0
Then try to restart it, are you running this over supported HW and with the Cisco provided OVA?
java
if this helps, please rate
7 Replies 7
Jaime Valencia
Is tomcat running?
java
Yes,tomcat service(started)
java
I restarted the tomcat service but teher is no change
Are you using a supported browser?
OK, are you running this on supported HW? And it this is a virtual install, did you use the OVA from cisco.com without altering any of the specs?
java
This system worked no problem last week.but after electric power cut this problem started
