Cisco CUBE Dial-peer Group
mohamedyare
Hi Everyone, I hope everyone in the community is doing well.
I have 4 SIP connections terminated to the vCUBE (PSTN, Webex, Teams, and on-prem CUCM). I am using DPG on each incoming dial-peer to route the call to the outgoing dial-peers. However, on the DPG, I created dial-peer preferences for each dial-peer (preference 1, 2, 3). When an incoming call hits the DPG dial-peers, it checks all dial-peers one by one, and that takes a long time for the call to connect. Is there a way I can fix this issue to reduce the time it takes for the call to be connected (30-40 seconds) or sometime matches incorrect outgoing dila-peer?
example:
voice class dpg 4
description From Teams to Webex or CUCM or PSTN
dial-peer 6 preference 2
dial-peer 2 preference 3
dial-peer 4 preference 1
I completely deleted all DPG and dial-peer associations, then reconfigured and tested each one individually. Therefore, I assume the main issue was a call loop. I am utilizing a combination of server-group, e164-pattern-maps, and DPG.
5 Replies 5
Jonathan Schulenberg
The precision approach to solving this would be e164-pattern-maps so each TN has only one appropriate destination. This is also the most efficient for CUBE; every additional dial-peer it has to hunt through lowers the Calls Per Second capacity since it’s additional load on the CPU.
It shouldn’t take that long to fail through a dual-peer unless the far end isn’t responding. Are you sure there isn’t a call loop happening here? What does the far-end reply with when sent an INVITE for a TN it doesn’t have? CUCM should send a 100 and then 404, at which point CUBE should immediately hunt to the next dial-peer (unless you’re also using server groups within the dial-peer, then it would have to repeat this process per-server.)
Where are these dial peers actually going? Based on your description on the DPG it looks like you’re sending it to 3 different services, CM, Webex or PSTN. IMO that is not a great structured DPG. Also if you are using server groups as @Jonathan Schulenberg mentioned you should add this to the server group, huntstop 1 resp-code 404 to 404, to not have it hunt trough all the servers in the group.
Response Signature
mohamedyare
Thanks gents. The issue is now resolved.
Glad to hear that. For the good of the community it would be great if you please took the time to give a little more details on what you did to solve your issue.
Response Signature
