Cisco CUBE H323 trunk to Polycom RPAD
VTCpeter
Hi all,
I'm a bit of a newbie when it comes to CUBE configuration and I'm currently trying to configure an H323 trunk between the CUBE and a Polycom RPAD.
The full path of the call will be: CUCM -- SIP -- CUBE -- H323 -- RPAD -- SIP -- DMA
What I currently have configured in the CUBE (parts of it at least that I think are relevant):
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
dial-peer
destination pattern ...
session target ras
codec transparent
I think I'm missing some more parts but I cannot seem to find any information about this in the documentation.
Anyone who can point me in the right direction?
6 Replies 6
R0g22
"session target ras" is relevant for Gatekeeper deployments. Is your GW going to register to a Gatekeeper and let it handle the call admission ?
You basically need "session target ipv4:X.X.X.X" where X denotes the RPAD IP. You would need another dial-peer with a session target pointing to CUCM for calls coming in from the RPAD.
R0g22
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book.html
Go through the "CUBE Fundamentals and Basic Setup" chapter. Will be helpful.
So.. I'm back on this issue. In the meantime I read up a little bit more on the CUBE but I'm still having issues with this type of setup.
So my GW will not register to any Gatekeeper no. It's just there for the interworking between H323 and SIP.
I got the call going out from the CUBE to the RPAD and I see the call coming in on the RPAD on H323 but after the H323 setup message I immediately get an H323 releaseComplete message from the CUBE.
Any ideas what could be the issue?
Hard to tell without any further details. Get the logs for the following -
debug h225 asn1
debug h245 asn1
debug ccsip message
debug ccsip error
debug voice ccapi inout
Attach running-config from the CUBE as well.
running config attached and debug log below.
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30F4B0CC, addr=20.3.66.42, port=42606, local_addr=20.3.66.62, connid=2, transport=TCP
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:9580025400211@20.3.66.62:5060 SIP/2.0
Via: SIP/2.0/TCP 20.3.66.42:5060;branch=z9hG4bK47120545b8
From: "Polycom-HDX7000-R10U7" <sip:9580065400200@20.3.66.42>;tag=7299~22cf8212-c4a5-4dcb-8b2f-2a1bcc05cdcd-30359136
To: <sip:9580025400211@20.3.66.62>;tag=2148D3EC-22E8
Date: Tue, 27 Mar 2018 13:25:29 GMT
Call-ID: 4ff33000-aba14649-36-2a420314@20.3.66.42
User-Agent: Cisco-CUCM11.5
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: presence
Content-Length: 0
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x2AEB3418
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 20.3.66.42,Port 42606, Transport 2, SentBy Port 5060
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone ZULU to SIP default timezone = GMT
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:485338828 ConnTime 0
Mar 27 13:29:04.144: //1136/4FF330000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B952564, Tag=0x0, Call Id=1136,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 27 13:29:04.144: :cc_free_feature_vsa freeing 2AF71D60
Mar 27 13:29:04.144:  vsacount in free is 0
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/State/sipSPIChangeState: 0x2AEB3418 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2AEB3418
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 9580065400200
Called Number            : 9580025400211
Source IP Address (Sig  ): 20.3.66.62
Destn SIP Req Addr:Port  : 20.3.66.42:5060
Destn SIP Resp Addr:Port : 20.3.66.42:42606
Destination Name         : 20.3.66.42
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 470
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[374] removed.
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2AEB3418 key=4ff33000-aba14649-36-2a420314@20.3.66.429580025400211
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_FreeSipRawSdp: no sdp to free
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/ccsip_offer_ans_delete:
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/ccsip_iwf_delete:
Mar 27 13:29:04.144: //1136/4FF330000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 2AEB3418
Mar 27 13:29:04.144: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[374]
Mar 27 13:29:06.320: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
Mar 27 13:29:06.320: //-1/xxxxxxxxxxxx/H323/cch323_send_event_to_ras: Queued event CCH323_RAS_EVENT_TIMEOUT to RAS Global SM
Mar 27 13:29:06.320: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
Mar 27 13:29:06.320: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_TIMEOUT while at CCH323_RAS_STATE_GRQ state
Mar 27 13:29:06.320: RAS OUTGOING PDU ::=
value RasMessage ::= gatekeeperRequest :
      requestSeqNum 366
      protocolIdentifier { 0 0 8 2250 0 4 }
      rasAddress ipAddress :
        ip '1403433D'H
        port 61459
      endpointType
        vendor
          vendor
            t35CountryCode 181
            t35Extension 0
            manufacturerCode 18
        gateway
          protocol
            voice :
              supportedPrefixes
        mc FALSE
        undefinedNode FALSE
Mar 27 13:29:06.320: RAS OUTGOING ENCODE BUFFER::= 0000016D060008914A0004001403433DF0132800B500001240013C05010000
Mar 27 13:29:06.320: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_GRQ state
Mar 27 13:29:11.320: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
Mar 27 13:29:11.320: //-1/xxxxxxxxxxxx/H323/cch323_send_event_to_ras: Queued event CCH323_RAS_EVENT_TIMEOUT to RAS Global SM
Mar 27 13:29:11.320: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
Mar 27 13:29:11.320: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_TIMEOUT while at CCH323_RAS_STATE_GRQ state
Mar 27 13:29:11.320: RAS OUTGOING PDU ::=
      requestSeqNum 366
        ip '1403433D'H
        port 61459
      endpointType
        vendor
          vendor
            t35CountryCode 181
            t35Extension 0
            manufacturerCode 18
        gateway
          protocol
            voice :
              supportedPrefixes
        mc FALSE
        undefinedNode FALSE
Mar 27 13:29:11.320: RAS OUTGOING ENCODE BUFFER::= 0000016D060008914A0004001403433DF0132800B500001240013C05010000
Mar 27 13:29:11.320: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_GRQ state
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_send_event_to_ras: Queued event CCH323_RAS_EVENT_TIMEOUT to RAS Global SM
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: received event CCH323_RAS_EVENT_TIMEOUT while at CCH323_RAS_STATE_GRQ state
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_ras_get_alt_gk: Entry
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_ras_reset_alt_gk: Entry
Mar 27 13:29:16.320: //-1/xxxxxxxxxxxx/H323/cch323_run_ras_sm: changing to CCH323_RAS_STATE_GRQ state
Mar 27 13:29:23.560: %SEC-6-IPACCESSLOGNP: list SNMP_SERVERS permitted 0 20.3.0.92 -> 0.0.0.0, 458 packets
The logs are not complete. Can you increase the router buffer and/or the scroll back for your telnet client and try again please ?
