Cisco ISR4331 V Router PRI Connection CUCM Configuration
amalmichaelvj
Hello Cisco,
Someone please explain the configuration in Cisco Router ISR4331V ,For PRI connection.
I have 32 channel PRI connection for PSTN connectivity,Router will primary gateway to CUCM via MGCP protocol.
please help me to configure the ISR Router.
Jonathan Schulenberg
What effort have you put into researching this thus far? Where are you stuck? A simple Google search would provide sample configs, for example:
https://community.cisco.com/t5/collaboration-voice-and-video/mgcp-gateway-integration-with-cucm-and-pstn-service-provider/ta-p/3116588
One thing people get hung up on the ISR 4K is the TDM clocking:
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/feature/guide/isr4400netclock.html
