Cisco Jabber 12.6
Drewmusonza2857
Hello, I am trying to auto populate the advanced settings during installation, mainly these two areas..Select your account type: Cisco Communication Manager 9 or later and Use the following Server: . see image attached
i tried something like this, but it did not work: msiexec /i ciscojabber.msi  /quiet clear=1 Authenticator=CUCM  TFTP=mycompany.com
 msiexe command did not work also am not sure which xml file i can update to enter these setting
Jaime Valencia
If you want to use Jabber in phone only mode there is no need to use any switches, configure your SRVs, do not enable the user for IM&P, and just configure the CSF device and associate it.
java
if this helps, please rate
Jaime Valencia
java
