cisco jabber MRA question
abd88elhak
i have cucm  and presence 10.5 and expressway X8.5 and cisco jabber 11.9
the normal stituation when a user try to connect with cisco jabber throuh MRA must be connect locally first and accept cerificats of cucm and presence servers and then can connect on MRA
but now this senario not happend
the only change made is i reainstalled presence server (because active disk 100%) and restored the databse
so what should i do to  back to normal situation
Best regards
Jonathan Schulenberg
A full DRS restore including the Platform should have restored the same server certificate.
Does a client that has previously connected successfully get prompted with a new certificate warning when connecting on the internal network? It shouldn’t if the restore was done correctly.
Try a Refresh Server on Expressway-C to see if that cleans things up. A restart of Expressway-C/E might be worthwhile as well.
PS- The correct way to address this is installing CA-signed certificates so Jabber doesn’t prompt the user in the first place.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-presence/116917-technote-certificate-00.html
Hi jonathan
 when deploying cisco jabber MRA  a user should connect first locally  and then from extern or can connect directly from extern by internet ?
i'm talking about a user new user configured
best Regards
In current releases and when properly deployed a user can connect through MRA the first time. There are a few rare exceptions such as CAPF enrollment but the most common deployments do not need to connect over the internal network first.
