Cisco PCD Cluster Discovery Timeout
voipchild
I am doing a cluster discovery in preparation of a migration via PCD.
My cluster consists of two CUCM pub (ga2) and sub (ga1), and two IMandP pub (jab2) and sub (jab1).
CUCM pub (ga2)and IMandP pub (jab2) in LAN2
CUCM sub (ga1)and IMandP sub (jab1) in LAN1
The problem is that when i did a discovery, CUCM pub (ga2) and IMandP (jab2) discovered succefully,
but CUCM sub (ga2) and IMandP sub (jab2) timeout.
Note: there is no firewall problem, all needed ports are open and there is no any blocking.
Additional info:
PCD version 12.5
Cluster:
CUCM - 9.1.2.15900-7
IM&P - 9.1.1.31900-1
Any thoughts or suggestions would be greatly appreciated!
Thanks in advance.
Vaijanath Sonvane
Please check if there is any cop file install in progress under OS Administration. If yes, then Assume Control and cancel it and try again. If it doesn't work then restart the cluster and try it again.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Hello Vaijanath,
I have checked if there is any cop file install progress and there is not.
I restarted the cluster and try again a discovery and it run perfectly.
Thank you very much.
