CUCM SIP TRUNK with Huawei PBX
mohammedobaid
Dear All,
I configured a SIP trunk with RP, RL and RG
when I call to the other site which is Huawei PBX
Calls from Huawei PBX to CUCM is working fine
Connectivity is WAN
Issue: As I initiate calls from cisco ip phone I get a Busy Tone and call gets disconnected
Vaijanath Sonvane
Are you using CUBE Router in between or is there direct SIP Trunk between CUCM and Huawei PBX? Please post logs of your existing failed calls.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Direct without CUBE router and about logs RTMT is also not working fine
Without checking logs, it will be difficult to know what the issue is. Re-check your SIP Trunk configuration. Here are few URLs for SIP Trunk configuration:
https://www.devconnectprogram.com/fileMedia/download/c7536066-015c-4c20-85f8-4c79cfec7272
https://support.yeastar.com/hc/en-us/articles/218130557-How-to-Connect-Cisco-Unified-Call-Manager-to-MyPBX
I hope this will help you.
