Cisco Presence: View Privacy Policy via SQL-Statement
I'm looking for a possibility to have an administrative look at the "whitelist" or "blacklist" a user can configure via the Presence User Options.
To be more specific, I want to see which user are allowed or blocked in the "Privacy Policy" of the user.
As far as I know it is not possible to view them on the Web GUI of the Presence server.
But I think it should be possible to view this with an SQL statement and the "run sql" command on CLI. Does anybody have any experiance with this and can help me?
I need this for troubleshooting.
Christian
htluo
Level 9
Level 9
run sql select * from pefilterinfo where pkid=(select fkpefilterinfo from epasprivacypolicy where fkenduser=(select pkid from enduser where userid='htluo'))
Replace 'htluo' with the user ID you want to query on.
Michael
http://htluo.blogspot.com
Hello Michael,
thank you for the answer. Unfortunately this Query gives not exactly what I need. I'd like to have a list of userids which have special allow/block status in the privacy policy of this user.
Your Query gives this result:
pkid                                 filterid filterdata        isstandard datetimestamp
aedc9b46-1ffc-4a20-8de9-c841250b7e42 38902
f          1265880602
Christian
Sounds like "Cisco Developer Support" is what you need.
http://developer.cisco.com/web/cdc/home
Michael
