Cisco Prime PCD - Problem migrating from cucm 8.0.3.20000-2 to 11.5
kasper123
Level 4
Level 4
We are trying to migrate a cluster of CUCM 8.0.3.20000-2 running on two MCS servers to 11.5 on new cisco servers running vmware.
We discovered the cluster and the ESXi servers and created a migration task.
After we start it it runs for some time and then it fails with this in the task log:
ERROR The selected server version was not found (or is not supported). Jul 17, 2017 17:26 CEST
ERROR Failed to create platformConfig.xml file for node 86_192.168.100.10.flp.Please check the afg library logs from PCD. Jul 17, 2017 17:26 CEST
ERROR Export job for node cucm.ttt.local failed.
ERROR 1 nodes(s) in Export task action ID #87 failed: cucm.ttt.local
The PCD is version 11.5.3.10000-14
Old cluster: 8.0.3.20000-2
New iso: Bootable_UCSInstall_UCOS_11.5.1.12900-21.sgn.iso
Does anyone have an idea what could be wrong?
16 Replies 16
kasper123
Level 4
Level 4
In the end it turned out that the problem was with the .iso file even though the presented error seemed like there is a problem with exporting the configuration of the first node.
With a new correct iso file the migration went smoothly.
Out of curiousity, could you compare the hash of the iso to the one posted by cisco?
